Topography section hatch not showing correctly
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1639 Aufrufe, 3 Antworten
Why does the fill of my topograhy section only show on one part? (There is the same terrain than the left part)
I want it all to have a hatch. Thanks
3 ANTWORTEN 3
Nachricht 2 von 4
constantin.stroescu
als Antwort auf: Anonymous
Pay attention to Phases visibility. If you made excavations , they are probably on New Phase , the rest is on Existing....
Constantin Stroescu
Nachricht 3 von 4
Does the section cut through the entire topo?
Nachricht 4 von 4
RevitRx
Also double check your site properties (the teeny tiny arrow at the bottom right of the topo section of the site tab on the ribbon) but it looks like you're only cutting through a portion of your topo (when not cutting through it is shows as a plane - similar to your right side. Phasing also could be causing this, if you split your topo or have a building pad in that spot.
www.RevitRx.com
