topography rendering issue- strange layer of topo
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
655 Aufrufe, 4 Antworten
Hello,  I'm getting a strange additional layer of what seems to be a gray topography layer a few feet above the actual topography.  Can't for the life of me figure out what it is (many hours researching).  It's not visible in the view other than when rendered.  See image.  Thank you.3D View 6 rendering layer issue.jpg
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, it's difficult to guess without opening the file. Is there any possible you can share the files so we can check. thanks
Nachricht 3 von 5
als Antwort auf: ennujozlagam
Finally figured it out.  I turned off autocad imports in the views.  Thank you though :leicht_lächelndes_Gesicht:
Nachricht 4 von 5
ennujozlagam
Hello, glad you figured it out, please do remember when you do a rendering either in cloud or in revit program itself you need to remove all your link cad and import files or else it will take time to render your model. thanks
Nachricht 5 von 5
Will do.  Thank you and be well!
