Which material did you specify in the above example?
I would open Manage > Materials > locate the material above > Render Appearance > and verify the image is located and set accordingly.
I would also verify that if you set the Visual Style > Realistic, does the material still show gray or appear as it should?
Please let us know, thank you,
I would open Manage > Materials > locate the material above > Render Appearance > and verify the image is located [no errors] and set accordingly.
Ryan Duell
