Topography Lines not Showing
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
2777 Aufrufe, 2 Antworten
Hi!
I've made a topography by points, but I don't get to visualize the lines of the different levels on plan or 3D out of edditing mode (where, only then, I get to see at least the points of the lines).
Does anyone know what it might be? And how can I see the lines composed by the points I've made?
Thank you very much!
2 ANTWORTEN 2
Nachricht 2 von 3
cbcarch
als Antwort auf: Anonymous
Check your Cut Plane/View Depth in the Plan View
Check if Topography and Primary and Secondary Contours are turned on in Visibility/Graphics>Model Categories>Topography
Check your Site Settings under Massing & Site Tab (-hit small arrow at lower right corner of Tab )
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 3
als Antwort auf: cbcarch
"Check your Site Settings under Massing & Site Tab (-hit small arrow at lower right corner of Tab )"
It worked!
Thank you so much! :leicht_lächelndes_Gesicht:
