I have a site that has an underground parking structure and I was wondering if there is a way for the outline of the walls that are under the topography to not show up on the topography when looking at it on the plans or 3D view besides just hiding the walls of the underground parking structure.
Why would it show if it is under the topography? Did you model the topography properly?
When I placed the walls under the topography the tops of the walls show up on the plans which is an issue I have had issues with before especially when the topography is relatively flat and nonexistent
If you are using a building pad under the parking structure, there will be no topography showing above the structure and walls. Contrary to many of the Revit experts, you can trace the building pad outline (and structure) with the Split Surface tool. This will create a new separate topo with contour lines over the underground structure. In Section, you override and eliminate the ground poche on the topo cover.
Jeff.
