I created my topography bu using the topography point tool. It was at 640' above sea level and I wanted to move it down to 0'0'', but every time i go to move it past 0'00' the topography gets deleted. Please help, I've been trying to figure this out for hours.
Click on the dropdown arrow on the site / massing tab and lower the topo elevation base (or something sounds like it). That or something that indicate where to start drawing the topo contour lines.
Hi..
topography uses ' Project base point "
1. You may move " project base point " with " clip" or " without clipping" ( its like pin on the project base point )
2. The second optionis try these checks.. constraint, disjoin .... try to move in elevation or section view..
while moving topography
Best luck
