Topography from csv : z value points are rounded up to zero decimal
1 ANTWORT 1
Nachricht 1 von 2
archconcept.morin
182 Aufrufe, 1 Antwort
I am importing a topography via a csv file. When I selec a point in the newly created topography, the elevation data is rounded up to meters with zero decimals.
My units are set as meters with 2 decimals, and when I look at the csv file, there is no roud value in there.
What am I missing here?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: archconcept.morin
Are you selecting a point from within toposurface edit mode?
...or do you mean you are placing a spot elevation? If so, those units are controlled via the Spot Elevation Type Properties.
