Topography cannot be selected in 3D View
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
fitrananda.24116120
741 Aufrufe, 3 Antworten
hi there,
I wonder if someone might be able to work out how I can select and edit my topography.
I can see & select my topography from Site & Elevation, but in 3D view i can't select it. I tried VG and turned everything on.
I don't know whats wrong with this?
Thanks if anyone has any thoughts. Files below.
Tags (2)
3 ANTWORTEN 3
Nachricht 2 von 4
there is a known issue for this see LINK  or make your screen two view (tile) on is your elevation or site and the other one is your 3D view > go to your elevation or site plan view  > pick the topography > then go to your 3D  view and see if you can select. thanks
Nachricht 3 von 4
how about my topography not change after i change visual style?
Nachricht 4 von 4
do you have any view template assign in your view > change to none or have you assign materials in your topography? or your topography is part of your of site plan linked file? thanks
