Topography: Can an imported "existing" topographical model be imported and merged with "proposed" topo model?
2 ANTWORTEN 2
Nachricht 1 von 3
aaron
154 Aufrufe, 2 Antworten
As the title says, i have an existing topographical model in Revit. I have a revised site plan with modified topography that wasn't a "Graded Region", but merely a modified "existing" model. So, there is no direct way of quantifying cut and fill out of two separate RVT files. Question: Is there a way I can import the "existing" model into the "revised" model and join them so that the phases are "existing" and "new construction" primarily so a Topo Schedule will read the cut and fill?
Thank you, in advance, for your guidance.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: aaron
 Not possible.
Nachricht 3 von 3
aaron
als Antwort auf: barthbradley
Bummer.
