You go to massing and site. Click on the small arrow and change the section graphic elevation of poche base
FWIW: Keep in mind that it is called a "Toposurface" because that's all it is - a SURFACE. It is not a Mass-like element that has Volume and Depth. The Poche you see in Section Cut is only a symbolic representation. Massing & Site Tab=>Site Settings.
Note: Poche only shows when Toposuface is CUT in the View by Section Cut Plane or 3D Section Box.
Are you familiar with how to create a Roof by Mass Face? Maybe you can use this approach to accomplish what you want.
1. Export your Toposurface to DWG
2. Start an In-Place Mass Session in Revit
3. Import into the Session the DWG you exported out of Revit in step 1
4. Finish and close out of In-Place Mass (ignore Warning)
5. Create a Roof by Face from the Mass you created
That's the short version. Here's the long version:
Figures that came from Marcello.... LOL... In looking at the handout I think I may have actually attended that class.
Howard Munsell
its in the name, topography is a surface and not element with any thickness.
probably you can increase the thickness of the cut line in the section if that solves your issues.
