ok so i think i had majorly screwed my topo surface.....
It wont let me make a subregion.
1. when i sketch a subregion and press the big green tick it displays:
'Subregions cannot intersect'.
2. Just as a test, when i try to make a building pad and hit the big green tick again and it it tells me:
'The Site Surface failed to triangulate. It happens if a Subregion be completely inside/overlap a BuildingPad. It may happen in other situations as well.'
3. The topography is displaying as a grey colour when the material is set to <By Category> therefore should be displaying as a green colour.
These 3 clues lead me to believe that the toposurface may have a giant subregion already encompassing the whole thing?
But for the life of me i cant find/select it to delete it
I've attached the file if you want to get a play.
Thanks for the help in advance
hi @Anonymous,
I think you have two issues there.
I will have a look at your file,
François
Francois-Gabriel Perraudin
BIM management and coaching
re-hi @Anonymous,
I have checked your model and everything work fine on my side... see proof picture.
On the other hand, be careful of two things:
Then everything should be fine!
PS: if not solved, try doing exactly the same operation on another computer so check the problem desn't come from your revit install...
François
