Topo to ifc export from Revit 2019
27 ANTWORTEN 27
GELÖST
Nachricht 1 von 28
4335 Aufrufe, 27 Antworten
Dear sir/madam
We are working on IFC viewer to meet our client requirement in that IFC file, we are facing an issue while exporting the topo from revit to ifc,
in revit our topo is part by part but once export its convert in to a single surface, kindly advise me on this part, i add the export setup for your reference
Step 01Step 01Step 02Step 02Step 03Step 03Step 04Step 04Step 05Step 05
27 ANTWORTEN 27
Nachricht 2 von 28
als Antwort auf: Anonymous
What do you mean by the above statement? "Part by part"?  "Single surface"?
Post a picture.
Nachricht 3 von 28
ari.monteiro
Hi @Anonymous!
If I understand your issue, you have a toposurface comprises by multiple parts and you want export to IFC these elements as a single part, correct?
Could you share some images of your toposurface for analysis, please?
Nachricht 4 von 28
als Antwort auf: ari.monteiro
Hi sir, thanks for your reply, yes you are correct sir, i will share the image now image.png
Nachricht 5 von 28
als Antwort auf: barthbradley
our issue is topo surface comprises by multiple parts and once we export to IFC these elements as a single part
Nachricht 6 von 28
ari.monteiro
Hi @Anonymous!
Configure the Export IFC Options like following image. Depending IFC version, this configuration will be different.
With this setting each part of toposurface will exported separately.
If you'll use the ifcSite class on Topography category, the Toposurface will be exported as single element, regardless you have modeled each part isolately.
Please, let me know if you got solve your issue, ok?
Best regards!
Prof. Ari Monteiro
BIM Consultant at Dharma Sistemas
www.dharmasistemas.wix.com/home
Nachricht 7 von 28
@ari.monteiro  : What about Topo Infills created by Building Pads?
Nachricht 8 von 28
Thanks for your reply sir,
once we export, our export layer as mentioned below sir
by using this step also our topo convert in to surface sir, kindly advise for the further steps
Nachricht 9 von 28
ari.monteiro
Hi @Anonymous!
To export the building pads to IFC, setting at "Site->Pads" category in "Export IFC options" the IFC class "IfcFooting" like the image below.
After, just export the IFC file using the same configurations that you presented in you first post.
Best regards!
Prof. Ari Monteiro
Nachricht 10 von 28
ari.monteiro
Hi @barthbradley!
See the solution tha I suggest for @Anonymous  about building pads. The ideia is the same of toposurface, this is, to define the properly IFC classe in "Export IFC Options" window.
Best regards!
Prof. Ari Monteiro
Nachricht 11 von 28
Hi sir, for building pad we will follow your steps and update you sir
for topo we are using the below mentioned settings
by using this steps also our topo converted in to IFC as a single surface, kindly advise sir
Nachricht 12 von 28
ari.monteiro
Hi @Anonymous!
I'm sharing at link below 3 files:
1. The project that I've used to study your issue
2. The ifc file for this project, exported as I suggested
3. The configuration IFC file that you can load in "Export IFC Options"
My test files
https://drive.google.com/file/d/17IaLlNTvNx4625rnktKDh7I5lmLDBTKw/view?usp=sharing
Please, check these files. You'll be note that in my IFC the toposurfaces coming as a seperated elements and bulding pads is exported, too. The image bellow show how my IFC file is visualized into BIM Vision software:
Two important information: I'm using Revit 2019 update 2.2 and IFC 2019 (version 19.3.0) export extension.
Maybe, you should update you Revit and the IFC export extension. The last version of this extension can be downloaded by this link:
https://apps.autodesk.com/RVT/en/Detail/Index?id=1763588736399554049&appLang=en&os=Win64&autostart=true
Best regards!
Prof. Ari Monteiro
Nachricht 13 von 28
Thanks for the details and your support sir, i will check that and update you sir
Nachricht 14 von 28
Thanks for the steps and the data's sir, its very helpful for me to solve that issue, you are great sir bcz we are struggling for past 3 weeks to solve this issue, with in 3 chat message you understand our issues and solve that issues easily, thanks again sir
Nachricht 15 von 28
ari.monteiro
Hi @Anonymous!
I glad to know that I helped you!
I'm a BIM consultant in Brazil and I would invite you to visit my website (www.dharmasistemas.wix.com/home) to known a little more my job.
Best regards!
Prof. Ari Monteiro
Nachricht 16 von 28
Sure sir, Thanks for your support
i have one more doubt in the revit to ifc export, can we export an ifc along with architecture wall thickness? sir
kindly advise sir
Nachricht 17 von 28
ari.monteiro
Hi, @Anonymous!
To export the wall thickness to IFC you should use the "IFC2x3 GSA Concept Design BIM 2010" setting.
Best regards!
Prof. Ari Monteiro
Nachricht 18 von 28
Thanks sir
Nachricht 19 von 28
Hello, can i have the 3 files previously shared? Thank you very much in advance
Nachricht 20 von 28
szetkova
Hello @ari.monteiro,
I am trying to achieve the same, unfortunatelly are the data not on google drive any more. Could you please tell me what set up needto be changed in order to get separate parts of the topography?
Thank you very much, best regards
Simona
