topo survery from dwg
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
pushenergy
625 Aufrufe, 13 Antworten
can someone tell me quickly which layer i need to bring in from the attached CAD file to create a contour map? i gte mixed results i thought it would be the contour layers?
13 ANTWORTEN 13
Nachricht 2 von 14
Sahay_R
als Antwort auf: pushenergy
Major and Minor Contours.
What mixed results are you talking about
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 14
@pushenergy
Can you save the DWG to 2013 version?  I can't open 2018 files.
Nachricht 4 von 14
als Antwort auf: ToanDN
I'm a little confused. The dwg is planar. There is no definition.
Nachricht 5 von 14
Sahay_R
als Antwort auf: barthbradley
You can save AutoCAD DWGs back to an older version.
Can you share a RVT with the incorrect toposurface on it?
Rina Sahay
Nachricht 6 von 14
als Antwort auf: Sahay_R
What, @Sahay_R? I opened the DWG just fine. It's a 2D drawing. There is nothing to articulate a contoured surface in it.
Nachricht 7 von 14
Sahay_R
Yes it is a 2D DWG. That's what the OP is going to use as a basis to drop his points on to generate elevations. And I was not the one who had trouble opening the file.....
Rina Sahay
Nachricht 8 von 14
sorry. guess that sounded challenging. My bad. Verlegener Smiley
Nachricht 9 von 14
ennujozlagam
@pushenergy   hello, layer of contour point is SS_LEVEL_PNT.  there should be a value of your Position Z once you link your cad into revit to create a toposurf., unless you key-in your elevation point manually. thanks
Nachricht 10 von 14
als Antwort auf: ennujozlagam
LMAO!!! That's exactly the point I have been making: There is no "Z" in the dwg.  This begs the question: WHAT IS THE QUESTION?  "Can someone tell me quickly which layer I need to bring in from the attached CAD file to create a contour map?" What does this mean?
...okay, sorry. Just having a rotten day. Love you all.
Nachricht 11 von 14
pushenergy
Yes there are Z points i have now found them on a layer called 3D points,
Nachricht 12 von 14
ennujozlagam
@pushenergy hello, you are right the layer is SS_3d it was freeze that why we don't see them. thanks
Nachricht 13 von 14
Viveka_CD
Hi there @pushenergy
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Nachricht 14 von 14
als Antwort auf: Viveka_CD
yes sorted now thanks i cant see answered  option....
