TOPO FROM ACAD
4 ANTWORTEN 4
Nachricht 1 von 5
332 Aufrufe, 4 Antworten
TOPO FROM ACAD
ive exported a comma delineated file from acad (attached) and when i try and make a topo revit tells me - no points were found in this file AND some rows from the file could not be used?
help pls.... im not sure of the file format to save the comma delimited file and have tried all......
ive also tried to export csv file (attached) - and i cant seem to get this to turn to topo.....
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
You can also import the CAD file in to create the topo from, then delete it.
I will look at the txt file when I get to the office see what went wrong.
Nachricht 3 von 5
als Antwort auf: ToanDN
not sure if i included acad dwg - points at x,y,z......
ive tried also just bringing in acad and making topo from that - wont even let me select as import to make topo from..... ;-(
Nachricht 4 von 5
Make sure you have "select linked files" enabled in the lower right corner.
Nachricht 5 von 5
Sahay_R
Your CSV file has all values in one column.
Try this file.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
