Topo contour lines not showing correct
itisme_yourboss
itisme_yourboss
There is a certain dwg file with topographies and I need Revit to display exactly the same lines as in AutoCAD. I tried, I placed everything in Revit by dots, but the lines are not displayed.
Note: there is dwg file which i use.
hmunsell
You have 2 different screen shots not sure which is which 😁.  but I'm assuming the one with the points is the incorrect one.
  1. Open the AutoCAD file and use the JOIN tool and pick all the lines to join the lines together.
    • 12554 objects converted to 830 polylines
  2. Then use the PEDIT tool and pick Multiple, select all the lines again and pick Join.
    • 7869 segments added to 168 polylines
Then try bringing the DWG into Revit.
Howard Munsell
