My countour label don't indicate at 1000mm intervals.
I can't figure out how to get all my levels to display the same in 3D and in plan view. SP and PBP both set to 0.0
Move the Topo up 70.
Help | Define Site Settings | Autodesk
...move the Contour Label's Elevation Base (e.g. Project Base Point or Survey Point or Relative Level) 70.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-945D511C-CE83-41B6-88FC-2CD940EB2A6C
Hi @brettK7GUZ
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
