Top sloped floor
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
mairh_tsek
1244 Aufrufe, 6 Antworten
Top sloped floor
Hello all,
I have a floor and I want to keep the bottom level as it is and create a slope in the upper level. From 40cm thinkness that I have at the edges I want to have 60cm thichness in the middle (like the green lines in the section image below).
I did the floor variable  and I tried to make the slope with the Modify sub-elements tool but the slope in the middle isn't 60cm..
How can I do it?
Thank you in advance!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: mairh_tsek
Do you mean like this?
Nachricht 3 von 7
Did you put a Split Line down the middle and set the set it's elevation to 60?
Nachricht 4 von 7
mairh_tsek
als Antwort auf: barthbradley
Thank you for your answers,
Yes this is what I did, but in the middle I dont have the height that I want. The shape of the floor is not rectangle.
Thank you!
Nachricht 5 von 7
mairh_tsek
Actually look the example below.  The slope is 60cm in the middle as I want but I dont know which is the correct way to do it.
  • In the first floor I added a Split Line in 0.20m elevation in the middle of the floor and also a point in 0.20m elevation.
  • In the second floor I just added a split line in 0.20m elevation.
In the section view, in the second case from the right side to the left there is a part which seems to be flat.
Which one is the correct way in order to have a 0.60 elevation height in the middle  of the floor?
Nachricht 6 von 7
FAIR59
When you use [ Modify Sub Elements ] for the first time, every cornerpoint on the boudary gets the default value 0.
Changing the height of a Sub Element ( point or split line ) only effects that Sub Element.
After changing the height of your split line to 0,2m. you have 2 points with height 0.2m, all the other boundary points are still at 0 !!. To get a smooth surface, you'd have to calculate and set the height for all the points.
A more user friendly method:
  • make a simple floor shape (rectangle).
  • apply Split Line, add set height
  • trim the unwanted parts of the floor using 1 or more Vertical Openings. [ Architecture ] [ Opening ] [ Vertical ]
result: a floor with only 6 Sub Element Points, easy to modify
Nachricht 7 von 7
mairh_tsek
als Antwort auf: FAIR59
@FAIR59  ,
Thank you for your idea! it seems to work for me.
