Toilet partition won't attach to wall face
3 ANTWORTEN 3
Nachricht 1 von 4
maddyj
360 Aufrufe, 3 Antworten
Hi everybody, i have a Revit issue that i fear is not a quick fix (or rather, something that i need to fix within the family). I have a toilet partition that is attached to the wrong wall (see screenshot), and when i select "pick new host" it does not allow me to select the wall i want to attach to (which is the wall right in front of where it is currently.)
Any troubleshooting tips greatly appreciated!
Thank you in advance!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: maddyj
Change Wall Join at the corner to Miter.
Nachricht 3 von 4
You cannot do this via Pick New Host?  Why? How's it hosted?  To a Vertical Surface? Offset from host then. Not Pick New Host.
Nachricht 4 von 4
tlcom913
All toiletsadviser look the same, but when it comes to performance, there are significant differences between all of them. All toilets are not made for the same purpose, that’s why you need to select the right one for your needs. For instance, the best strong flushing toilets are specially created to flush away large waste and prevent clogging issues.
