(I think there should be a forum dedicated to family creation and editing, not necessarily discipline specific)
Anyhow... I have to toggle between 2 options in a family, it's either one element, or another. I currently have a visibility parameter on each that I control them with. X2 since I have this condition on each side of my family. So I uncheck one, then check the other. How can I set this up to be controlled by a single toggle? Thanks.
Gelöst! Gehe zur Lösung
Gelöst von rodrigo.bezerra. Gehe zur Lösung
Hi
You'll use a formula. Let's say that you have a yes/no parameter A for an option, and a yes/no parameter B for another. Choose one of them and apply the formula "=not(parameter name)". As exemple: "not(B)" will automatically turn visible all A when B is unchecked.
Regards
PS: click HERE to find "everyday formulas".
Rodrigo Bezerra
Hi @rodrigo.bezerra, I'm hoping you can assist me with something to this solution: How can one make use of this feature if there are a number of options to display; say 6.
I'm trying to create a furniture family that will display a different number of nested furniture families (workstations desks), depending on what is selected in the properties of the family. i.e If I select "cluster of 2", from a drop down menu perhaps, then the family will display 2 desks. If I select "cluster of 6", then 6 desks area displayed; etc. I would like to create 6 of these within the family.
Hope this makes sense
Rodrigo Bezerra
