To create a wall scheduler, the structural parameter does not appear in the list of parameters for a schedule
why not?
Structural Usage value is set to "Non-bearing" if the Structural Yes/No parameter is set to No. So just use Conditional formula (ie IF(....) to check for the value and act on it accordingly.
Hi @info
I just wanted to follow up here, any progress on this issue? Did the resolution by @bimscape help withyour issue?
Do you seek more assistance from the community?
Please mark any posts that help with "Accept as Solution" and thanks!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Wall
Structural Material in Wall Property
Structural Material
Hi..
Make sure you have ticked / Assigned Structural materials for wall...
in Wall schedule , structural material should pop up..
Good luck
