To create a wall scheduler, the structural parameter does not appear in the list
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
info
817 Aufrufe, 7 Antworten
To create a wall scheduler, the structural parameter does not appear in the list of parameters for a schedule
why not?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: info
What Structural Category parameter field do you need to add to your Wall Schedule?
Nachricht 3 von 8
info
als Antwort auf: barthbradley
I picked the category walls
and i want to choose the build in instance parameter  Structural
Nachricht 4 von 8
You mean you don't have a "Structural Usage" in your list of available fields to pick from?
...oh, I think I get it now. On the fields tab the "Select available fields from" has a drop down box. Look in there.
Nachricht 5 von 8
SteveKStafford
If you are referring to the Structural parameter (check box instance parameter) for walls, it is tied to another parameter called Structural Usage in the available fields list. They don't provide access to the parameter (Structural) from within schedules (walls), I don't know why sorry.
Steve Stafford
Nachricht 6 von 8
Normally when you check the Structural box then an Analytical wall is created, then you can pull the parameter from it to the Wall Schedule.
Nachricht 7 von 8
info
als Antwort auf: ToanDN
it shows the result.
but I do not think it's the same as the Structural parameter.
for example, in the build in parameter loadbearing, a checkbox will be displayed in the schedule
  for the parameter structural, a checkbox should also appear in the schedule
i want to be able to use a schedule to change te parameter.
With Dynamo it is possible to change de parameter Structural.
Why is not possible to change it in a schedule
or does it have anouther name?
Nachricht 8 von 8
I do not understand why they left it out of the available parameters.  I showed you a merely workaround: you can highlight the rows in the schedule, Highlight in model, CTRL+Tab to switch to a model view, amd change their Structural box from properties with a single click.
