to create a parameter by a formula
3 ANTWORTEN 3
Nachricht 1 von 4
tcardia
310 Aufrufe, 3 Antworten
Is it posible to create a parameter by a formula for a system family element?
I need to create a parameter that subtracts the diameter of a pipe of the same dimension, would that be possible?
thanks
3 ANTWORTEN 3
Nachricht 2 von 4
azad.Nanva
als Antwort auf: tcardia
what did you mean? by python , dynamo or other way?
In revit normal formula, no you can not.this is not the programing language.
Nachricht 3 von 4
CorstenGroup
You may have to explain it bit more.
Nachricht 4 von 4
Corsten.Au
Hello
Am attaching how to create a parameter which can pick any existing parameter ( like Diameter )
and you can further use it. even to subtract from itself.
Let us know if that helps or you have some other issue.
ScheduleScheduleCalculated ParametersCalculated ParametersReuse ParameterReuse Parameter
Corsten
Building Designer
