To create a double wall opening
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
m.pharamawy
2745 Aufrufe, 10 Antworten
In the video i explained the problem in making a wall opening family cuts in double wall, if someone can help i'll be very grateful
10 ANTWORTEN 10
Nachricht 2 von 11
L.Maas
als Antwort auf: m.pharamawy
If the two parallel walls are close enough together a simple join of the walls can do the trick
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 11
m.pharamawy
als Antwort auf: L.Maas
that's great,
u mean that if the walls are close enough then i don't need to add a void to the family?
ok, if so, what is the definition of (close enough) how can i control the tolerance or range ?
and what if the walls are not close enough? what can i do to make my family effective ?
thanks for ur reply, u added a great information to  me
Nachricht 4 von 11
m.pharamawy
additionally, what is the program u used to capture ur video :leicht_lächelndes_Gesicht: :leicht_lächelndes_Gesicht:
Nachricht 5 von 11
L.Maas
Yes, correct. I believe the maximum distance is about 150 mm. This distance is hardwired in Revit and as far as I know can not be controlled
Depending on your project other alternatives might be:
-Make use of a wall opening.
-Create a single wall definition incorporating both walls.
-Create a face based family consisting of a void and place that on the other wall.
I used Screencast (free from Autodesk). you can find it HERE.
Louis
Nachricht 6 von 11
Sahay_R
All else failing - add a void to your window family. Use the Cut command after inserting the window. It should cut through the other wall too.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 7 von 11
Attached is an example of a door family with an opening cut to cut the host wall AND a void to cut the secondary wall.  After place the door you have to perform Cut geometry to cut the second wall should it be too far from the main wall in order to join.
p/s: when someone says you cannot have both an Opening cut and a Void in a door or window family, don't believe them.
Nachricht 8 von 11
m.pharamawy
als Antwort auf: Sahay_R
@Sahay_R
@ToanDN
thanks a lot for u both, specially for @ToanDN as i used ur family to learn what is the problem in my family, i discovered that the problem was that i used reference plane to adjust the void distance, but u used reference line, i don't know what is the difference between them but ur method worked and mine didn't
when i modified my family using a reference line the problem get solved..
thanks very much
Nachricht 9 von 11
Did you try the family in my file? It's hard to tell how you built the family based on the video. Can you share it?
Nachricht 10 von 11
m.pharamawy
als Antwort auf: ToanDN
Yes. Finally i opened ur family and got the problem? Did u read my reply?
Nachricht 11 von 11
No I replied before I read it. Glad it worked.
