TitleBlocks
5 ANTWORTEN 5
Nachricht 1 von 6
263 Aufrufe, 5 Antworten
TitleBlocks
Hi guys,
does anyone know why text would be off centered and scrambled like the attached shows? I didn't have this problem until I updated to Revit 2018. Is it a possible bug or my PDF creator? I use CutePDF. I used it in Revit 2016 before I updated and it worked great! Also, the text is centered and looks just how I type it in Revit, but when I PDF it, it goes out of whack.
5 ANTWORTEN 5
Nachricht 2 von 6
Sahay_R
als Antwort auf: Anonymous
This was one of the side effects of the upgrade from 2016 to 2017......
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 6
als Antwort auf: Sahay_R
I think @Sahay_R may be right on here. Autodesk suggests that you upgrade sequentially; not skip. Maybe this is why? We have no such like issues at our end.
Good luck
Nachricht 4 von 6
Alright guys, I uninstalled 2018 and installed 2017 which solved the titleblock problem,however, the only thing that's missing in 2017 is the stuff above the ribbon (see attached). Did this happen to any of you when you went to 2017?
Thanks guys!
Nachricht 5 von 6
AH! I had the exact same problem when I first installed 2017. Has something to do with Dynamo. I believe 2017.2 will correct for you.
Nachricht 6 von 6
als Antwort auf: barthbradley
You were right! Did the update and now it's there. Thank you!
