Titleblock transparant logo on background color
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
Xapod
339 Aufrufe, 5 Antworten
I run into the following issue when creating my titleblock family.
The titleblock contains a big rectangle and inside of this rectangle is the company logo.
I would like to be able to set a color background for this rectangle with the logo visible on top. However when I place the logo (image as .tif format with transparent background) the image messes up the background color.
See screenshot to better understand the problem
Is there a way to fix this?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Xapod
Convert the TIFF to PDF and place it.
Nachricht 3 von 6
Xapod
als Antwort auf: ToanDN
Thank you for your quick reply. However i tried it and I still get the same result?
Nachricht 4 von 6
kostask_oionei
Have you tried with transparent .png?
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 5 von 6
Share the TIFF file here, assume it already has an alpha channel.
Nachricht 6 von 6
Simon_Weel
Save yourself a lot of hassle - enlarge the logo canvas to cover the rectangle in the title block. Revit doesn't do transparency in images.
