Hi all,
I have shared parameters that define the size of the titleblock and should be displayed in the header. However somehow they dont show up and instead question mark is displayed. Does anyone know what could be the issue?
I attach revit file as well.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If i assign them in my project it still don't retrieve the values of the sheet i get nothing instead if i type a value in the parameters (in sheets) then it shows in the label.
What i want that if the titleblock changes (width or height) the label update automatically.
by the way every titleblock has already parameters sheet width and height how to use this one to show up in a sheet?
