Titleblock - Revision Schedule
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
aTeresaAfonso
765 Aufrufe, 12 Antworten
Hi!
I have a titleblock with a revision schedule included, but que text shows up outside the boundaries.
Anyone can help me?
12 ANTWORTEN 12
Nachricht 2 von 13
Yien_Chao
als Antwort auf: aTeresaAfonso
can you share the .rfa?
Nachricht 3 von 13
Nachricht 4 von 13
aTeresaAfonso
als Antwort auf: Yien_Chao
Yes. In attach.
Nachricht 5 von 13
Is that what you see in Revit or PDF?
Nachricht 6 von 13
What are we looking for in this TBLK Family?  A particular Family Type?  You have so many.  Which one?
Nachricht 7 von 13
aTeresaAfonso
als Antwort auf: ToanDN
Revit
Nachricht 8 von 13
aTeresaAfonso
als Antwort auf: barthbradley
This elements is common to every type. The legend is always the same.
Nachricht 9 von 13
@aTeresaAfonso wrote:
Revit
The revision schedule is wrapping text correctly here.  Are you using a Virtual Machine?
Nachricht 10 von 13
Yien_Chao
works here. i fix the appearance options.
Nachricht 11 von 13
Yien_Chao
here the file
and the settings i choose
Nachricht 12 von 13
aTeresaAfonso
No, I am not using a Virtual Machine.
Nachricht 13 von 13
aTeresaAfonso
Thank you very much. It has to do with the header, if they are on, the text shows ok. I didn't think in that. Thank you again for you quick reply.
