Titleblock Revision Over 3+ columns
SaraDavis-SMRT
SaraDavis-SMRT
Community Visitor
Community Visitor
How do you create a revision status in a titleblock that is more than 2 columned segments?
We have created a schedule per column segment (see image below). Each one has a condition associated with it and they read as follows...
The first one reads "if(Revision Sequence < 3, Revision Number, " Condition 1")" and it works great. Once you go to the second revision schedule that is where we run into the problems.
The Second condition reads "if(and(Revision Sequence > 2, Revision Sequence < 5), Revision Number, " Condition 2")" but depending on the amount of revisions within a sheet it may appear perfectly or it could appear below or above where we would need it to show up but it does stay within its constraints given above.
Is there a way to create this sequence to come out in the proper order within the 2 rowed lines on the table?
