I am having an issue when exporting from Revit to DWG - I can export views just fine but when I export sheets, i run in to a few odd things namely; Titleblock is never present in the DWG (I've tried many families and tried from different models, same result), Schedules are missing, Legend views are sometimes present but gets misplaced far from where it's placed on the sheet in RVT.
I've played with the export setting in any way I could think of, tried adding layer modifiers to the titleblock layer settings, tried exporting to all different versions of AutoCAD - I'm at a loss.
I'm in RVT 2020.2
Anyone experience this before?
have you try to tick default export options and see if helps. thanks
Hello @jonas.namensen Thank you for posting to the forum.
Are the projects from a template or are you transferring project standards from other projects?
Does the same problem happen when you create a brand new project from a default 2020 template and add the same titleblock to this new file?
What are the results when you open a sample file and export a single sheet to dwg?
C:\Program Files\Autodesk\Revit 2020\rac_basic_sample_project.rvt
