Title Block Text
5 ANTWORTEN 5
Nachricht 1 von 6
571 Aufrufe, 5 Antworten
Title Block Text
I want to create a parametric title block label that is equal to the value of the parameter below which is from a wall family I have created.  Any help is much appreciated!!
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
"A parametric title block label that is equal to the value of the parameter from a wall family"???  Huh? That doesn't make any sense.  Can you walk us through exactly what you are thinking?  Maybe give us an example workflow?
Nachricht 3 von 6
als Antwort auf: barthbradley
Im sorry, Im new to Revit after making the switch from autocad.  Lets try this again, lol.
I have a wall family, one of the parameters in the wall family is the thickness of insulation that is in the wall.  This thickness changes from wall to wall.  It may be 1" on the north wall, but then change to 3" on the east wall. I want to create a titleblock field that will be equal to the thickness of the insulation.
Does that make any sense?
Thank you!!
Nachricht 4 von 6
RobDraw
To what end? What is that "field" used for?
Rob
Nachricht 5 von 6
There is no relationship between a titleblock family and any model components. Create a wall schedule to report the fields of the walls and place the schedule on sheet in project.
Nachricht 6 von 6
Corsten.Au
Create a simple 2d Annotation family, and place it on ( multiple ) sheet.
any parameters created in titleblock cannot be linked to project/live element.
( with few exception to project parameters / inbuilt )
you can create some parameter in title block, but then you will end up editing it manually,
do it if thats what you are looking for..
Corsten
Building Designer
