I have 2 sheets, one existing and one proposed. Everything is at 1:100/
On the first sheet it says 1:100 in the title block, but I can't change this because it is greyed out.
On the second sheet it does not say anything and i can't go in the properties box here it says scale. Scale there is greyed out.
I thought they might have a drop down so I can pick 1:100 for both.
Shall I delete the label in the family and just put some text over it on the sheet?
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
The builtin scale property for sheets is automatically determined by Revit depending the scale(s) of the placed views on the sheet. If you place views with different scales it will state "As indicated"
- Michel
Oh, thanks Michael, I didn't realise that.
Yes, it has correctly recognised that all the scales on my first sheet are at 1:100, and there are no views yet on my second sheet, which is why it showed the scales blank.
Thanks for your reply.
