My sheet is showing up in my Project Brower but when I click on the sheet, nothing is there!
How do I fix this problem?
When you create a sheet you can choose a titleblock type for it. If your sheet is created without one, then go to view menu > and place a Titleblock on your sheet. You need to place views on sheets as well.
Huh? So, under Annotations you see the Title Block Family Name but no Type underneath it? Is there a "+" sign next to the name, or a "-" sign?
Did you try Zoom Extent? (ZE for shortcut). If you did, select the object in the blank screen and see if there are objects that are far away from your sheet from views.
Type VG or VV to access the Visibility Graphics Overrides charts - go to the Annotation Categories TAB, and make sure the Title Blocks are turned on. I just discovered I had about 10 Title Blocks placed all over the drawing. ![]()
