Title block image won't print
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
2588 Aufrufe, 15 Antworten
Hi.
I have created a title block with an image of the company logo in it. The image appears fine in the print preview but will not actually print.
Thanks in advance..
15 ANTWORTEN 15
Nachricht 2 von 16
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk community! Smiley (fröhlich)
Are you printing to a Plotter or to PDF?
Try saving to a dwf format and then print the dwf.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Nachricht 3 von 16
als Antwort auf: Viveka_CD
Printing to a plotter. The dwf doesn't work.
Nachricht 4 von 16
-FDC-
Can you send the file to check it ?
Nachricht 5 von 16
als Antwort auf: -FDC-
Title block attached. Thanks.
Nachricht 6 von 16
-FDC-
Must be something with your pdf printer.
Works fine here.
What pdf printer are you using ?
Nachricht 7 von 16
Am I being stupid? I'm sending it to a plotter, not a PDF?
Nachricht 8 von 16
-FDC-
Sorry, my mistake.
What plotter is it?
Nachricht 9 von 16
HP Designjet T520.
Nachricht 10 von 16
Viveka_CD
Hi @Anonymous
Disable the option for SpoolSmart® if it is present in the HP print driver preferences.  This option is typically located in Printing Preferences > Services > Troubleshooting Menu > Enable SpoolSmart.
Un-check the box to disable this feature.
Let me know if that works.
Nachricht 11 von 16
Hi.
I do not have the option to click the troubleshooting menu. It is greyed out?
Nachricht 12 von 16
-FDC-
I am working at home today and cannot check the HP printer settings but I found something about the same problem.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/I...
Let's hope this helps.
Nachricht 13 von 16
Is this it?
Nachricht 14 von 16
Viveka_CD
Hi @Anonymous
Please check if you have the printer driver installed from HERE
Also which windows version are you using?
Nachricht 15 von 16
windows 10
Nachricht 16 von 16
Viveka_CD
Hi @Anonymous
Yes, I looked the screenshot, did you uncheck that option?
Also, Windows 10 is compatible with HP Designjet T520. Please confirm if you have the latest print drivers installed? See HERE for more information.
(Install additional drivers highlighted below and see if it resolves the issue)
Tags (1)
