I am trying to follow a tutorial on the making of title blocks, but apparently some things are missing from the menu bar while I am inside the block.. when in a normal project its all there..
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von Revit_Whisperer. Gehe zur Lösung
You would add a shared parameter to the titleblock and then tie it to the project
Hey,
Your UI looks fine. If you are seeing less tabs than you see in a project is because you are in a Family file, and that change a little the tabs you can see and use. What would you like to achieve?
