Tire Wall for Earthship Designs
3 ANTWORTEN 3
Nachricht 1 von 4
rejames1969
981 Aufrufe, 3 Antworten
I was looking into designing my house using Revit and I am going to be designing an Earthship type home. If you go to www.earthship.com you should be able to get an idea of what I mean by tire wall. Is there any way that you can create a new type of wall and have it as an update to the 2017 version and then standard in the versions to come? There are some tire walls that would be straight up and done and others that actually lean back into the berm that is behind the tire wall. Please do a little research and see if that would be something that you could incorporate into the software. I know a lot of people that would love to be able to use Revit to design an Earthship type home.
Thank you for your time and have a great day.
Robert James
Beschriftungen (3)
3 ANTWORTEN 3
Nachricht 2 von 4
lionel.kai
als Antwort auf: rejames1969
Nachricht 3 von 4
@rejames1969
Maybe you should post a picture of the specific system you want to build instead of make others go to a website with tons of information and play Russian roulette.
Nachricht 4 von 4
Dear Robert James
Did you find a solution about the tire wall?
I'm looking for the same thing
Thank you
Giulia
