any tips on how to create battens for timber roof. I am struggling with creating proper battens on top of the rafter. Any help would be greatly appreciate it.
Gelöst! Gehe zur Lösung
Gelöst von Ilic.Andrej. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Define them in a "Sloped Glazing" Curtain Wall.
...see this: https://www.youtube.com/watch?v=BVyWefr_UGE
Hello @Anonymous !
I assume you mainly wan't to display those battens in section views?
If this is the case, I will tell you my practice. I create a roof with all its layers. One of those layers represents space where those battens will be installed. Then, in section views, I use 2d components to enrich the drawing.
I attached family which I usually use for any wood elements that are hidden inside of walls, floors or roofs. That could be a stud, a rib, a batten...
Is just a masking region. It has two instance parameters: "a" and "b".
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
...or use the OOTB Detail Item component ("Nominal Cut Lumber-Section.rfa") found under "061100-Wood Framing". ![]()
Wow! This is wonderful. It is exactly what I wanted it for. This saved me a lot of time.
and it is adaptable so it's perfect!
Out of curiosity what do you use for tiles?
Also, how do you create a the other layers? you duplicate the roof, with different thickness?
Thank you very much for the help.
Thank you for the video, it is a bit hard because there is not voice, but it gets the job done.
Thank you
Thank you for the suggestion, but how do it get it? is it a family I have to upload from library?
Sorry, I don't understand how to use this.
Thank you.
I' m glad we helped! ![]()
I just create one roof (its type has multiple layers). Open up type properties, "edit" structure and explore ![]()
Every layer has a material assigned to it. So, a tile material will be assigned to one of the layers.
Andrej Ilić
MSc Arch
Okay, I actually get it now, I Just have to find it in the library!
Thank you!
Thank you again for the reply,
So under libraries, I have U.S Metric, U.S imperial, and then I have different countries. I couldn't find a folder named: OOTB, I found another detail folder for the Malaysia folder, but it is not there. Am I missing something.
Thank you.
Thank you very much Dr_Grozozo, the multi layer roof worked. but I will probably have to upload a tile family so it can appear in the section.
Thank you again.
Thank you.
Sorry for the confusion. “OOTB” stands for “Out of the box”, meaning that it’s included in the initial install. In this case, I’m referring to a family “Rough Cut Lumber-Section.rfa” that is found in the Imperial Library under the folders: “Detail Items” > “Div 06-Wood and Plastic” > “061100-Wood Framing”.
I see. Thank you for the clarification. I think for me, I don't have the full imperial library. maybe because of my installation settings.
Thank you for your time.
