Tilting or changing the vertical angle of a suspended light fixture (family) on a sloped roof ceiling?
2 ANTWORTEN 2
Nachricht 1 von 3
zahedzmirza
196 Aufrufe, 2 Antworten
How can a suspended (Pendant) lighting Fixture be tilted on a sloped roof ceiling?
Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
Alfredo_Medina
als Antwort auf: zahedzmirza
An easy solution is to host the lighting fixture on a horizontal plane, such as a named reference plane, or a floor or level, if the family's type of host allows that. If not, then it's not so easy, you need to edit the family to add a rotation angle, which might be time consuming. I would do the first approach, if possible.
Nachricht 3 von 3
