Tile Pattern Not Rendering Correctly
13 ANTWORTEN 13
Nachricht 1 von 14
lee.imbimbo86EM4
630 Aufrufe, 13 Antworten
I'm trying to figure out why my material is not rendering correctly.  I'm trying to use Revit's Tile Pattern method to get the seamless image of the stone tile, with the right color grout applied, but when I do it significantly lightens the source image, and I don't know why.  it will show it correctly in the Tile's Texture Editor palette and then not correctly in the Appearance Tab.  See the attached, below, and when applying the tile pattern method to it, it takes the source seamless image for the tile itself and then just lightens it up significantly.  I don't see any mechanism to undo that.
Any ideas?
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: lee.imbimbo86EM4
Check the settings here (circled in red):
BTW: Porcelain Satin has some reflective properties.
Nachricht 3 von 14
lee.imbimbo86EM4
als Antwort auf: barthbradley
So regardless of Finish selection made, or scene selected nothing seems to change.  It is still taking the seamless image I linked and dropping it from a rich dark color to this very whited out version.  Its almost like it is applying a gray mask over the whole thing.
Nachricht 4 von 14
Sounds like Reflectivity to me.
FWIW:
 https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C...
Nachricht 5 von 14
lee.imbimbo86EM4
I wish it were, but there is not a single factor controlling reflectance, reflectivity, or other item I can fine.  I mean I attached the source file for the seamless image, it is pretty dark.  Why else would it be applying this graying out layer over it.
Nachricht 6 von 14
What Version of Revit?  Try another.  Any difference?
This is my result using your Image and Image Fade at around 30.
Nachricht 7 von 14
lee.imbimbo86EM4
I'm using Revit 2023.  So what's weird to me, when you use a starting template for a "tile" material, not a "default" material you do not get the fade control you used to control the material.  Any suggestions?
Nachricht 8 von 14
Some attributes are built in the specific appearance asset such as Ceramic: Porcelain vs Ceramic.  If you want a complete control of all attributes then use Generic asset.
Nachricht 9 von 14
Actually, there is an issue with 2023. I just discovered it.  I don't have a fix.  I'm going to Open a Support Case on it myself.  You can do the same.  The more the merrier.
Nachricht 10 von 14
Got a fix for you in the interim.
Create the Material in 2022 and add it to an ADSKLIB file.  Then, in your 2023 Project, open that ADSKLIB and load your Material.
Nachricht 11 von 14
Have you tried to adjust the brightness of the image under Tiles appearance?
Revit 2023 rendering samples.
0% brightness
31% brightness
100% brightness
Nachricht 12 von 14
lee.imbimbo86EM4
Barth - How do I get a 2021 material library accessible in 2023?  I haven't had a chance to try this out just yet, but I guess I assumed that the MATLIB2021 wouldn't be something that could opened in 2023.
Toad - It would appear that you're using a different tile material asset than I was using.  Let me try that one, and see if I get different results.
Thank you guys
Nachricht 13 von 14
I use the same asset as you do.
Nachricht 14 von 14
Thank you guys
Add it to a newly created ADSKLIB and open that ADSKLIB in whatever version of Revit you want.
