how to take the 3D colored icon on the model?
Also, where are the other site coordination icons to corrdinate w survey located on the ribbon, or where?
Thanks in advance,
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
tHEY ARE named Coordinates, I see the infor on Manger, but it does not say how to turn it off, neither is obvious under the VG dialog.
How to turn these colored arrows off?
Thanks again.
... hi @Anonymous
... yes , it is a well known issue with the 2020.2 update
... goto VG
... site
... and un-check the internal origin
… this thread has been around a lot since the update
… sometimes existing 2020 files are seeing the internal origin category being turned on in 2020.2
… sometimes upgraded projects from prior to 2020 versions are not affected
... it is a new addition to the REVIT layout in 2020.2 internal origin point
… top-5-best-new-features-in-revit-2020.2
…. they don’t print… so no problem … just get use to those
… also take a look at this forum discussion / explanation
… changing-internal-origin-default
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
