This site corresponds to a mirrored instance of the document. mirrored display of the current document is not supported. Please choose another site.
2 ANTWORTEN 2
Nachricht 1 von 3
r.ramakrishnanBHXEM
764 Aufrufe, 2 Antworten
Hi Revit Gurus,
I am getting below error message when I am trying to change (Make current) the coordinate/site.
"This site corresponds to a mirrored instance of the document. mirrored display of the current document is not supported. Please choose another site."
Please find out attached images for the above issue.
2 ANTWORTEN 2
Nachricht 2 von 3
Nachricht 3 von 3
The site that you are trying to make current is the mirrored instance of that Revit model. When you have more than one site location in one Revit model, you might be able to make current to the site locations which are not mirrored. So you might have a question why we need to keep the mirrored site location when we are not able to make it current? The answer to that is it is useful only when you link that Revit model into another Revit file. So when you are linking this Revit model in to another Revit model at that time you can select the mirrored site location and you can see it falls on the right location with mirrored instance.
If you find this answer helpful give me a Green tick.
