this part of the stair
Message 1 of 13
Hello. Is it possible that REVIT draws this part? It is a U shape Satair
THANKS!!!!!!!
Replies (12)
Message 2 of 13
No issues here.  Share your file.
Message 3 of 13
I share
Message 4 of 13
Just edit and redo one flight and landing. easy breezy.
End with Riser checked + flight/landing redone:
End with Riser unchecked + flight/landing redone:
Message 5 of 13
Message 6 of 13
Thanks a lot. Can I get rid of the arrow?
Message 7 of 13
Yeah, but you still have Warnings even with @ToanDN solution.  Or, did you not notice? Just saying...
Message 8 of 13
How can I watch the warnings?
Message 9 of 13
I think I have no warnings because it is off in grey
Message 10 of 13
I think if the inspectors don't  bring it your attention. the lawyers of the people using the stairs most probably will.  Then again, maybe you can get way with it long enough to flip the ownership.
Good luck.
Message 11 of 13
Do not understand what you means with lawyers etc. Anyway, i also have this issue with the railing, it does not get the upper part of the stair.
Message 12 of 13
well, i did, the thiferent parts, different measure so it has 2 cm in the middle, but i get this ugly thing
Message 13 of 13
anyboy knows if it is possible to do the railing right? Thanks
