This my question and request o want to know base on model text if Revit 2021 can edit model text...
2 ANTWORTEN 2
Nachricht 1 von 3
FacebookGroupMember
246 Aufrufe, 2 Antworten
This my question and request o want to know base on model text if Revit 2021 can edit model text to curve or arch if is yes how
2 ANTWORTEN 2
Nachricht 2 von 3
I know autocad can what about Revit
Nachricht 3 von 3
als Antwort auf: FacebookGroupMember
Pretty much a manual process.
Create a face based model text family with one letter and an instance parameter to edit the label and place it along a curved surface one by one (or use radial array). When done edit each instance using the instance label above. Similar approach if you want to arrange model text around a cylinder or a sphere.
