How to solve this problem that it shows "This model was transmitted using autodesk eTransmit for Revit" when I open the model?
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
It's like someone introduces his name to you. No needs to call the police. Once you know him, he won't need to do it anymore.
Save the file and you will not see the message next time. Until they send you new files.
FYI: eTransmit is a known vehicle for Ransomware. Only open if source is known.
So what you are saying is that you can open the file, but there's nothing in it. Is that about the size of it?
Yes, it always shows "This model was......". The model size is around 37MB.
You are opening a drafting view. Open some other view see what it has. And, your ELEC link is missing, better deal with that too.
Yes, I can see duct, diffuser, equipment on 3D view, but how can I see them in 2D? Thanks.
@Anonymous wrote:
Solved, thank you.
Good to hear. Now, how about a lil' green check mark? That is, close out this thread with an "Accepted Solution".
@tejaram46 wrote:How to get 2d views for that file
How to create them or how to view them?
