This is my problem . There is no entry to the architectural project start ...
Is this a new instalation?
If so the templates may have failed to install correctly.
If not.
Select the Application button (Blue R in top left corner)
Select Options
Go to file Locations and set the directory path to the needed templates.
C:\ProgramData\Autodesk\RVT 2016\Templates\UK\DefaultGBRENU.rte (my path, just to give a general idea)
ennujozlagam
hello. you can check it here. thanks
Click HERE
