Thin lines
5 ANTWORTEN 5
Nachricht 1 von 6
dian4189
383 Aufrufe, 5 Antworten
Thin lines
Hello, I am trying to change the lines weight, but the scale I am using is 1:300. I changed all of them to 1 to see if there is anything that changes, and it is not! How can I change it, and also how to export with think lines on, if that's an easier solution?
5 ANTWORTEN 5
Nachricht 2 von 6
pedruccioli
als Antwort auf: dian4189
Go to Manage > Additional settings > line weights
Add 1:300 and manipulate the values until you're happy with the results.
Hope it helps. Cheers.
Architecture Modelling, BIM Workflows and Information Exchange.
LinkedIn
Nachricht 3 von 6
dian4189
als Antwort auf: pedruccioli
I can not add the scale 1:300, since it is custom one, I can only use the scales that they are already there :enttäuschtes_Gesicht:
Nachricht 4 von 6
pedruccioli
I see. Try changing 1:200 and/or 1:500
LinkedIn
Nachricht 5 von 6
dian4189
I just did, but I do not see any change :enttäuschtes_Gesicht:
Nachricht 6 von 6
pedruccioli
Just tried it here. Changing 1:200 worked for 1:300.
Remember the thinnest line Revit prints is 0,025mm.
LinkedIn
