Thin lines
Thin lines
rraseloma145
Observer Observer
Thin lines
rraseloma145
Observer
Observer
Hello, is there a way were i can reduce the line weights in Revit to be less than 0.1000 mm because when i print .The ojects e.t.c are to thick for small detailng
Autocad is good at that but can't i get a solution in revit.Please check the attached screenshots of what i would like.
0.083 mm is the minimum line weight in Revit.
The issue you are having is not line weight. It's too many lines. Simplify. KISS. Save off the detailing for Detail Views.
