Thin Line weight in Wall elevation
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
shihas.pms24
364 Aufrufe, 6 Antworten
Hi all,
i want to print a elevation without line weight is it possible in Rivet? Wall projection line weight is too heavy in elevation i already try VG & object line style (Scale 1:100, weight -1, thick 0.0250mm) but no effect in
elevation still the same heavy thick line are visible.The attached image for your reference. The desired line weight  is marked in red color, also you can see the wall projection line weight as to be heavy. Any solution for fix it..................
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: shihas.pms24
Create/apply a PDF View Template that overrides all the Projection/Cut Lineweights to 1 (under View Visibility/Graphics Dialog).
...do you have Silhouettes applied in the View (Graphic Display Options Dialog)
Nachricht 3 von 7
Yes. Set the view to 1:1 scale. Print the view (not placed on sheet) scale to fit.
Nachricht 4 von 7
als Antwort auf: ToanDN
What about annotative elements?
Nachricht 5 von 7
shihas.pms24
als Antwort auf: barthbradley
No, Only for model Elements.....
Nachricht 6 von 7
shihas.pms24
But, How about this settings in floor plan. Because the Silhouettes already in None at VG Options. But here we can see the heavy line weight while turn on line weight. Or its applicable only in elevation view ?
Nachricht 7 von 7
shihas.pms24
all the Projection/Cut Lineweights i already set to 1 (under View Visibility/Graphics Dialog) but no effect in the view. still the line weight are heavy. the minimum line thick are 0.0250mm even though we didnt get the thin line. any other option get the line weight like autocad?
