Thermal loads and temperature
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
ericktavora
329 Aufrufe, 4 Antworten
I use Autodesk Revit 2020 (Educational version). When simulating thermal loads, when I change the temperatures in the "Climate/Weather" tab, the program always returns the same results, as if it did not consider the temperature changes. I even reset all the temperatures and the results are the same. What could be happening? Please
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: ericktavora
Nachricht 3 von 5
ericktavora
Thank you for your help, friend barthbradley. But the problem is that I change the annual temperatures and the thermal load results are always the same, as if Revit did not consider the temperature changes. Could it be because my license is educational?1.png4.png2.png3.png
Nachricht 4 von 5
It's a Subscription Benefit.  Says so in that Link I provided.
Nachricht 5 von 5
ericktavora
als Antwort auf: barthbradley
thank you very much barthbradley
