There is not enough memory to save. Increase the amount of available memory
jitu1dange
jitu1dange
Does anyone know why I am getting this error "There is not enough memory to save Increase the amount of available memory and try again.
The file I am working on is not huge, less than 100MB. And I have 32 GB of RAM, still getting this error. I have to close out of Revit and restart to fix the issue every time.
hmunsell
clean out your temp folder and make sure you have enough free hard drive space?
Howard Munsell
cdingleyWCJGC
I have the same exact issue - quite the headache! I only ran into this error message on Revit 2020. I have plenty of RAM and storage space; and it doesn't allow you to save a copy in other folders due to the same error message. The only solve I found has been to audit the file when you open it again. The major issue is that this doesn't get back any work you had completed since the most recent save.
Anyone have a better solution that doesn't result in a loss of work?
jitu1dange
Yeah, it's very frustrating. As of now, the only solution I found is to always open the model with the "Audit" option check and to clear out the Temp folder as often as possible.
BIMologist_
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
