there is an option to uncheck model categories for multiple linked model that on custom visibility graphic?
13 ANTWORTEN 13
Nachricht 1 von 14
edenbU7RGS
734 Aufrufe, 13 Antworten
i'll try to explain my self more clearly
maybe there is an option with dynamo to uncheck the visibility of some categories for multiple views (that are set on custom and not linked view) at once?
of course view templates will not help here
you can see here in the video the manual process that im doing now.
I need to edit the visibility graphic for each view to turn off the room color fill for example
13 ANTWORTEN 13
Nachricht 2 von 14
ennujozlagam
als Antwort auf: edenbU7RGS
how about filter?
https://resources.imaginit.com/support-blog/revit-how-to-filter-elements-from-a-link
Nachricht 3 von 14
RSomppi
Why not? I would have thought that would be the way to go.
Nachricht 4 von 14
edenbU7RGS
als Antwort auf: RSomppi
because i set the linked view to custom and pick the right view for each one.
Nachricht 5 von 14
RSomppi
Unless I am missing something, you can do what you are describing with view templates.
Nachricht 6 von 14
jvpantin2
The best way to coordinate visibility/graphics overrides is setting display "By host view" in Revit Links tab. Doing this, you can be sure all elements of same category show the same, no matter if they belong to host or linked models.
Set links visibility as "custom" is pretty annoying because is a one-by-one proccess and so plenty of mistakes.
Display "by linked view" will show link as it was set in a specific view on linked model, so if you want to change link's view setting you must go to that view on linked model. Annoying too.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Nachricht 7 von 14
RSomppi
als Antwort auf: jvpantin2
In my world, that is never acceptable. Our links are used mostly for elements of different categories than we model.
Mistakes happen when you aren't careful. It's actually a simple process. A bit tedious at times but pretty straight forward and because they all contain different elements in different categories, often times we don't have to be selective about what not to show.
I can see how your method could be helpful for some but it is far from the the best for most.
Nachricht 8 von 14
jvpantin2
It doesn't matter, you can change link visibility by host view anyways. AFAIK, all categories alwyas are available, so you can check/uncheck them.
Agree about be careful. But I worked a lot setting links as "custom" and then realize that it has no sense, unless specific custom visibility was really needed. Conclusion: never was.
So, I put my vote on filters, and on view templates too. Don't see Dynamo as an option.
Nachricht 9 von 14
edenbU7RGS
no cause im using custom, the visibility graphic is different for each view.
maybe i found a solution on this dynamo script
How to turn off certain Sub-Category for specific view types - Revit - Dynamo (dynamobim.com)
Nachricht 10 von 14
RSomppi
By host view does not work for us or any other place I worked. We simply need more direct control even if it means a little more work. Not using by host view isn't a guarantee for error. Most times we need to turn off select categories in links or, at a minimum, have them display differently from the host elements. If it works for you, fine. Saying it's best is far from accurate as I have never been able to use it at any place I worked.
Nachricht 11 von 14
RSomppi
You can still use a view template to apply the same changes to every view. The view template can control just what you want to change for that link. You can apply the same changes to each view (not multiple at once) from the template without having to assign the template or go into the visibility overrides,
Nachricht 12 von 14
blank...
You can select multiple views in project browser, right click, assign them all view template you want at once.
Nachricht 13 von 14
edenbU7RGS
als Antwort auf: blank...
it doesn't help because for each view I picked different linked view.
it's seems that there is no solution for this.
thanks anyway
Nachricht 14 von 14
RSomppi
There is a solution but you seem hesitant to go there.
